Ban-Bi_Pilot_Nigel
- Joined
- Sep 1, 2007
- Messages
- 4
I have a D100 installed in my MCR-01 (Ban-Bi), based in UK. Excellent equipment, no problems until Sat when, on boot, the display came up in greyscale, horizon bar swinging randomly, a/s and asi tapes cycling rapidly between zero and full scale.
2 warning messages appear: 1 "Attitude Indeterminate" and 2 "Internal Battery Error"
The unit failed to boot on several successive occasions with same symptoms. Unit last flown in May without fault and last booted correctly about 1 week ago for ground check, nothing out of the ordinary noted at that time. Aircraft has not been moved since, no evidence of physical damage. Main bus voltage 13.2V.
Unit s/n 1545, running Ver 3 software.
Original internal battery still installed, unit generally left with keep alive power to its breaker from main a/c batt.
Any advice appreciated, unit is removed from a/c pending probable despatch to you guys, hope you can help.
Regards,
Regards,
