D100 won't start below 2°Celcius
Patexocet
I,
Since few day the température was very cold in Belgium  -8°C . My Dynon D100 (model 2006) won't start before the température in the cockpit reaches 2 °C
Do you have a solution to solve this problem ?
Thank you.
Patrick
Patexocet
This post speak about the same problem
http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1259248788
Do you have a solution other then send you back the unit, I leave in Belgium...
The likely solution is to return the unit to us for repair. To avoid downtime, you might consider contacting our dealer near Strasbourg, France, named Finesse Max. They have some "Field Repair Units" available as loaners to install temporarily in an aircraft while awaiting return of a unit sent to us for repair.
The dealer's terms for loaning the equipment is at their discretion.
Contact Christian Stuck, Info@Finesse-Max.com
Patexocet
Thank you for the answer.
A other question is : Do you think that this problem suggests that I might have a problem in normal condition temperature (above 2°C) in the future ?
If not, I prefer to not sending back the unit to avoid fee.
Patrick
It is unlikely that this indicates a problem that will occur at higher temperatures.
What software version are you running on the D100?
