Hello,
I'm installing D10A with Ap74, EDC10 and two servo SV42 on my Tecnam P92 ultra light.
I would need to swap the servo arm by 180 degrees for best servo linkage attachment point in my installation. Is it correct swap 180 degrees the Range of Motion Limiting Bracket, supplied with the servo and simply rotate the arm 180 degrees by hands? Can the internal servo position feedback work well in all angles or is there a sector where it has problems?
Is it possible use UTP CAT6 cable ( network ethernet cable) for connect all data lines DAB, DSAB-B and EDC10 data (not power lines) ?
Thanks.
Thanks.
