D10A Audio out
rv8iator
Regarding the D10A...
Pin 18 is ndicated as audio out.  I can find no other references to audio in the install or operator guide.
1. Are there audio alarms?
2. How are they set (if there are)?
3. Is the audio out line level (2v p-p ?), if so can I feed it directly to the headset ie spliced into the intercom audio out line?
Thanks...
CS
The EFIS-D10A software does not currently output audio alarms. This feature is coming and will simply require a software update to take advantage of.
We recommend that you connect the audio output through a variable 10k resistor into your intercom's auxilliary input.
A
Andrew Rayhill(Guest)
I was wondering if you have plans to add voice warning for angle of attack? What other audible alerts will you be doing?
Andrew,
Any audio alerts we add will be tones, not voice. The D10A does not have the capibility to generate voice warnings.
I believe the only current plans are for AOA. Are there other things you would like to have warning tones on?
