tonyvaccarella
- Joined
- Jun 14, 2010
- Messages
- 18
Hi all,
I have updated information from my post dated 28th Aug about an inaccurate airspeed indication on my D10A.
I run a backup ASI and there is a huge difference between the two airspeeds indicated. When my old style ASI reads 100knots my D10A indicates 87 knots. At lower speeds the D10A under-reads by about 10knots.
Dynon kindly responded and said that they had checked thousands of these units and it almost always is the fault of the other ASI. Although I have used my GPS and conducted investigations that showed my old style ASI was more accurate, I took the information provided by Dynon to prove my old style ASI was faulty.
I constructed a water manometer that I found on the net http://www.iflyez.com/manometer.shtml
Today I ran some tests in-situ an with the D10A removed. Surprisingly I found my old ASI accurate according to the manometer and the D10A under-reads by 13 knots.
See images (I seem to only be able to insert 1 image. More available on request)
Is there anything I can do this end or does my D10A need a short holiday to the USA?
Many thanks to everyone who helped with my first post.
Regards to all
Tony
[/img][/img][/img][/img][/img]
Regards to all
Tony
