I have a D10A with latest software, it has a GPS feed but no NAV etc…
When checking various avionics in the hangar I have found that the ‘GPS Assist’ sometimes flashes up and then the pitch will shot up 20-30 degrees. I’m not yet flying the aircraft so not sure if this will happen in flight. Seems a bit weird.
I know that there is some coupling of GPS/pitot/gyros, could a dodgy GPS signal in the hangar be causing this? If the unit thinks it is moving but speed = 0 thus looks at GPS data?
Should I turn the GPS source off and check there isn’t some other internal issue?
Thanks in advance. Tim
