D10A Plumbing Kit
WEdgar
AP; IA
Sacramento
Dynon website lists a D10A Plumbing Kit 102628-000; when this number is entered in AircraftSpruce's website the results is a 10-03283; is this a typo?
It appears to be more than a Pn; comparing what appears to be in the kits is looks like Dynon should label the two different kits so it is clear to the user. Hopefully Dynon support will respond with some clarification so others will not waste time on this.
Aircraft Spruce part numbers are of the form XX-XXXXX, so that's definitely a spruce part number. Even when reselling our products, Spruce will give them their own part number. In this case 12-03283 (10-03283 listed above is something else - I assume a slight type-o) is a pitot/static plumbing kit, but I'm not certain that it is actually our 102628-000 part number. I'll check with them.
You can order ours from our store here.
Maybe TechSupport can provide some help on this.
On Dynon's web site D10A Plumbing Kit 102628-000 brings up a picture of the items in the kit; using the same number 102628-000 on Spruce's web site defers to pn 10-03283, which the picture clearly shows these are NOT the same kits.
Does Dynon have two different kits or what is going on?
We don't have two parts/kits. I don't have an answer from spruce yet on whether or not their part 10-03283 is ours, but with a different picture that they took of the contents, or whether it is a similar version that they manufacture. If you want to make sure you're getting the genuine Dynon kit, buy this one directly from us.
Back
