D10A spontaneously rebooting
gianmarko
last flight idid i had the D10A rebooting twice without apparent reason. i had the heating on because it was a cold day, and the heating sends hot air right under the instrument panel, so i suspect that could be the cause
i sent the D10A to dynon for repair once because the unit cyclically rebooted when warming up during normal operation. could be that the old "bug" is coming back?
Looking back at your last RMA, we did find a component that was more temperature-sensitive than it should've been. Testing after replacing that chip was done up to 85C momentarily, and to 60C for a more prolonged period (our spec is to 50C). All that said, if you're noticing a temperature correlation, it might be a similar problem that we'd need to have the unit back to look at.
