I'm debugging a new installing in my ship. ATC says they are not receiving my mode C information , just receive a Transponder Reply.
I guess I'm not getting my EFIS set up correctly to communication with my Garmin GTX327 transponder over the serial input wires. What Format do I need to set my D10A to so that the transponder will receive the BAR correctly? Also, there are multiple input option settings on the GTX327 to tell it what format it is being fed, so what setting do I chose on the GTX327?
Also, I have a Dynon blind encoder and split the serial output information from the D10A to feed both the transponder and the encoder. The gray Code from the Encoder feeds my Electronics Internation Super Clock. Presently, the "format" is set to "Format 1" and the SuperClock seems to recognise the input from the encoder. If something other than Format 1 is chosen as the output format from the D10A, will it continue to drive the encoder to put out the gray scale to my SuperClock?
Thanks, Marty
Thanks, Marty
