Don't have a metal panel. Can the white and black (very short) wire, out of the premade cable be tied to the same ground as the main ground wire?
Don't understand the paragraph that describes what the yellow with green stripe wire is or does. Help.....
Is a 3 amp breaker too large for the power source. I happen to have one and can't find a 2 amp locally.
Finally, I mounted the remote compass away from most everything but the cable has to run along side some antenna cables - problem??
THANKS!
THANKS!
