CheckerBird
We're trying to calibrate the D120 with Princeton capacitive sending units in an RV-10. The Princeton sending units are the 2-setpoint type, and the sending unit successfully went thru the initialization routine (empty + full) as described in its documentation just fine. We then emptied the tank and set up the D120 for calibration, telling it that the tank was 30 gallons, and it began the procedure prompting us to fill the tank 2 gallons at a time. Once we got to the 20 gallon mark, the sensor value readings pretty much stopped changing, the D120 kept asking us if we'd actually added fuel before pressing the ADD button. For the remaining 10 gallons, only once did it actually register a change. After pressing the ADD button, the sensor value displayed would start changing around, sometimes going up by a couple points, and sometimes going down. For the final 2 gallons, before pressing the final button to signify the tank was full, the sensor value on the screen dropped about 16 points from where it's peak value was. (peak was reported at 466, the final value was 450). Needless to say, the D120 reported that calibration had failed. We only did one tank thus far, and the resultant failed calibration says the Left tank with 30 gallons of gas in it displayed on the D120 screen as "Full" with 12.9 gallons in it. After power cycling the D120, then it showed 10.3 gallons and a full gauge graphic.
Any ideas what we should do to try to troubleshoot this calibration problem?
