D120 Rpm oscilates after mag check
Semperfubar
Hi...We have a d120 with two p-leads connected up with 100k-ohm resistances which have smoothed out the rpm jumps of about 300 rpm. It is now solid and works great...however after doing the mag check it starts oscillating again, if we reboot (on/off) the unit it is perfect for the rest of the flight...any ideas on how to stop this? It previously had 30k-ohm resistances. Thank you for any help....
When you do the mag check, do both of the mags check out OK and are smooth? The EMS is designed to use either of the two mags for rpm, switching over when it detects the loss of signal it was monitoring. That's how it accomplishes a mag check. You can get a momentary blip in RPM as it switches. So it's possible that one of your mags is still not getting damped enough by the resistance, and that's the one it's monitoring when you're done with the check. When you reboot the EMS it may choose the other one.
Semperfubar
Ok...we will do that check this week and probably go up to 150k-ohm resistances....thank you
Semperfubar
Ok...we have tried with 150k-ohm resistances, these improved the signal...however it was still a bit jumpy on the left magneto, ocasional blips up to 300rpm. We tried a 180k-ohm resistance on the left magneto...and it didn't improve, if anything it looked worse..So we went back to 150k-ohm....any other ideas? Thanks for your time.
Dynon Avionics EMS units have two inputs ("Left" and "Right") for RPM / Tachometer. The EMS unit only displays ONE RPM / Tachometer. The one that is displayed is "the first input that was receiving pulses". If, at some point, such as a Mag check", no pulses are received on that input, then the EMS unit switches inputs.
What you're describing - "... after doing the mag check it starts oscillating again", means that the EMS unit has switched to the other input.
Background:
The EMS-D120 and our other EMS units simply count pulses. With the Pulses per Revolution setting, the unit does a simple calculation: x number of pulses / pulses per revolution = displayed RPM.
While adding a resistor in series USUALLY "cleans up" the RPM signal so the EMS unit can reliably count pulses, some RPM signals are simply noisy, outputting extraneous pulses, and the EMS unit cannot distinguish between the noise pulses and the RPM signal pulses.
Potential solution 1:
Since, in your situation, you seem to have one "clean" RPM signal, and one "noisy" RPM signal, the "clean signal" is the first one seen, and the "dirty" signal remains during / after the mag check, perhaps if you swap the two RPM signals, then the signal that the EMS unit sees during and after the mag check will be the "clean" RPM signal.
Potential solution 2:
Some customers that aren't happy with the RPM display resulting from the normal RPM signals have resorted to installing a "tachometer generator" on the engine. This is a small unit that is mechanically coupled to the engine that outputs a "clean" RPM signal.
dlloyd
Locust, NC
I used to get an occasionally jumpy RPM indication but not to the point of being a problem worth fixing. Then I found oil had leaked past a seal into the right magneto. Rebuilt. Never had another jump.
