D180+Aera796
aerovolga
I have HS34 module and aera 796 GPS and I want to connect them together. I connected it to second serial port, and adjusted it, NMEA + 4800 baud rate, and adjusted aera 796 for NMEA out. FlightDek d180 doesn't see it. "Waiting for gps fix". What should I do? Does it really possible to get them work together?
They're known to work together. First, set the HS34 to 9600 baud. Also set the 796 to 9600 baud, with NMEA output selected (you may need to select NMEA plus TIS, which is fine). Finally, make sure that under the advanced NMEA setup that the data rate selected is normal, not fast.
