Hi!
I am in the process of connecting up the Dynon Jabiru 3300 Engine Kit supplied Sensors, upon installing the Current (GRT CS-01) Shunt and wiring it exactly as per the instructions, I get a Max Scale reading of +99Amps - even though there circuit is only pulling around 3 to 4 amps. Can anyone explain what is wrong here? There is only two sensors available in the setup - the second being the Hall Effect Type with an Off-Set adjustment.
Regards
Graham - Auzz
Regards
Graham - Auzz
