D180 fuel calib what do the numbers mean
karlb123
This was my first attempt at a tank level calib-
I had two notifications during the process which said no values have changed. At The end it said failed.
I know the senders are good as they have previously worked okay with analog gauges, this is me going from the old analog system removing that And going straight into the dynon.
What does this mean on the picture
So on the left you're seeing the voltages, in millivolts. so 2784 = 2.784V. The right side is gallons (I suspect you're calibrating in liters here, true?)
So basically, the D180 is only seeing the sensors move twice in the entire fill.
What kind of sensors are these?
karlb123
I understand now, yes in litres. I had a successful calibration on the other tank and reattempted the failed tank. Still failed but now only have the 0 and first 5l figures as issues
