I have not been able to display a glide slope on my D180 HSI page. I know that some time ago it seemed to work just fine.
I do display VOR and LOC signals just fine. I tried three different ILS courses with the same result.
I have a D180 and HS34, interfaced thru Approach Fast Stack Cables to a GNS430W as Nav1 and an SL30 as NAV2.
Neither radio shows the glide slope when selected via the HS34.
As I have checked antennas and connections, I was wondering if a configuration error on the D180, HS34, or the two nav radios might cause this issue.
I reviewed the D180 installation manual, and came across the note that when an HS34 is installed and the software updated, the SL30 should be disconnected. I can't remember doing this at the last update.
Logically, I think that if the CDI displays and reacts properly than the GS should also.
I would appreciate any insight.
Don
Don
