D180 - HS34 GP temp probe label
martinmcr01
Hello
I'm instaliing a D180 with a HS34. I've used all my available temperature probes. I have one GP probe left on the HS34 for monitoring CARB TEMP which i dont want to monitor. Can i change the label to read FUEL TEMP? I've aleardy used the general GP temp probe that you can change the label on elsewhere.
I'm running mogas and understand high fuel temperatures can lead to vapour lock. The CAA in the UK advise mogas should not be allowed to get to 20 degres centigrade. i was going to use a coolant probe in the fuel lline changing the label to FUEL TEMP
martin
MCR01
UK
Unfortunately, there's no way to have an additional custom-labeled temperature.
