D180 + IcomA210 + GPS2
a.bosi
Hi all,
I need to connect an Avmap Geopilot 2+ both to an Icom A210 and to my D180. Wich is the suggested wiring also considering to keep PC connection available?
Thanks from Italy.
Andrea
On the Dynon side, if you have a D180, use pin 19 on the EMS-side DB37 connector to receive the GPS input signal from the Avmap. Then you don't have to touch the PC connector (which is on the EFIS DB25 connector) at all.
