I am not able to get GPS info from my Garmin GPSMap196 to my D180. I have V5.0
I understand that if everything is working correctly, my HSI page should have a GPS flag. It does not.
There are four leads coming out of the Garmin plug: Red & Black; +12v & ground, white; data in, and brown; data out. I connected the white lead to Pin 19 on the 37 pin connector.
FYI here is a link to the Garmin manual. http://www8.garmin.com/manuals/GPSMAP196_PilotsGuide.pdf
The plug diagram is on page 101 and the GPS data info starts on page 95.
There are several choices to set the Garmin interface; GARMIN Data Transfer, Garmin DGPS, Aviatio In, NMEA In/NMEA Out, Test Out, RTCM In,RTCM In/NMEA Out, and RTCHM In/Text Out.
Am I using the correct wire? What setting should I use? What about the D180?
Any other suggestions?
