davejohnson
- Joined
- Apr 2, 2010
- Messages
- 10
I have now tried communicating with the D180 using each of the serial ports.
Using the EMS (37-pin) port, I get 'unable to communicate' even though it reports that it has found an instrument.
Using the EFIS (25-pin) port, I get the same result, although in this case the Dynon screen changes to the Yellow background. This port seems to work on receive, as it gets the time update from my GPS connected to this port.
The GPS was unplugged from the port for the test.
I have used 2 different computers, one of which has an RS232 port, eliminating the need for the RS232-USB converter.
I have used the other computer and the same RS232-USB converter to communicate with the D120 EMS on my other aircraft with no problems.
My principal requirement is to download the engine logs.
I have had many years in the computer business, so am familiar with the vagaries of RS232 communication.
I am coming to the conclusion that there is a problem with the Dynon, as I can't see what else to try.
Any suggestions would be welcome
