I am beginning the installation process of putting in my D180 in my Kitfox rebuild, Rotax 912UL, which will be modified with a Zipper big bore kit.
The plane originally had Westach gages, so most of the OEM Rotax sensors are gone. I have one OEM temp probe that I will use for oil temp.
I need information on 1. CHT sensors, 2. Oil pressure sensors and 3. Coolant temp sensor.
1. I was thinking of using the 12mm ring sensors for CHT, either under the plugs or in the OEM bosses with a fabricated adapter.
2. I need to source an oil pressure sensor. I believe the Dynon part suggested to use is p/n 101693-000. Should be plug and play…
3. I also need to source a Coolant temp sensor. I have found reference in the installation manual to Dynon p/n 100409-000 for the 1/8" NPT sensor. Is this sensor still available? I can't find reference to it anywhere...
