We are wiring a D180 on CTSW equipped with Rotax 912.
The wiring has been maid using dynon harness (for EFIS, Rotax 2 EGT, D37) but some probes are not working : the EGT (whiwh are original rotax ones) give a correct temperature as long as the engine does not work ( when it functions the temperature become negative until -80 °C).
We might have a wiring probleme : indeed we have used the diagram page 2-7 of flighhtDEK-D180 installation guide to wire D37 harness pin : on this diagram, the pin 3,5,16,17 are dedicated to groud but on page, 2-2 it is written that only pins 5-16-17 are dedicated to ground : what should we do with pin 3 ? can we connect it to a probe or should we connect it to the aircraft ground.
Is there a limitation in the number of probes, you can connect at the same time : we want to put as much as possible probes on this aircraft. will there be problemes of any kind (alimentation, lag ...).
On a D180, if you are using Dynon harness there are 2 RS 232 one from the D25 and one from the D37. If I want to update the firmware of a D180 do I need to wire my computer one time with the D25 to update the EFIS related data and then to wire on a second time with the D37 to update the EMS related data? (is it useful to keep both RS232, if the only way I will use them is to upload newfirmware)
Last question : is there a way to center exactly the ball on D100 or D180 (except by making a new hole for the panel) ?
innovair
innovair
