Hi. New member here. We have an issue with a Skyview D180K fitted to our P&W R985 radial engine. We are the second owners after the aircraft was modified and required.
We get multiple warnings on CHT and EGT, as well as Hi Voltage messages. I suspect this is related to some of the sensor probes becoming unserviceable. Is a common problem over time or with radial engines? Easiest way to replace or buy probes? Thank you
