D2 Startup and shutdown with ships power
rfazio1951
I know the D2 will start up when powered up from ships power. Can it be set to shutdown also when ships power is lost?
Yes, this is possible. From Page 6-2 of the D2 guide:
ADJUSTING SETTINGS
You can adjust settings such as ground speed units (KTS / MPH / KPH), altitude units (feet /
meters), whether or not the D2 turns off when external power is removed/lost, and whether the
D2 automatically shuts down after a period of inactivity. To adjust settings on your D2:
[ch61623] Press and hold the Menu Button to enter the Settings Menu.
[ch61623] Press the Rocker to advance through different settings.
[ch61623] Move the rocker up and down to adjust a selected setting.
[ch61623] When you are finished, press the Menu Button again to exit the Settings Menu.
Curious,
Thanks so much for getting back to me. I couldn't figure out how to get into the settings. Saw it in the manual but couldn't get it to work. Finally figured it out today. And see the settings.
RF
Back
