D60 to GTX327
norman111
My understanding is that I don't need an encoder to get my D60 to talk to my GTX327. Is there anyone out there that can tell me exactly what pins I need to hook up to the GTX327 from the D60? Any help would be most appreciated!!!
GTX pin 19 goes to D60 pin 13 ( pin 25 goes to ground at Gtx). Set the D60 ALTENC menu to Format 4 via the FRMAT button. :)
Jake J
norman111
Howdy, I have all the connections correct per the instructions below with the D60 at format 4 and I still don't have altitude showing on the Garmin...Any suggestions, something I am missing on the Garmin or D60 menu? Any advice is truly appreciated!!!!
Norman
You also need to configure the Gtx serial IN to Icarus Alt whether it's port 1 or 2 that you've wired the Dynon to in the GTX ;)
Jake J
norman111
Thank you for the quick reply! I have checked the Garmin and it is showing Icarus and port 1. I also did a continuity check of both the signal wire and the ground and they are good. This is really frustrating. Any ideas?
That should do it from the Dynon config end. And everything on the Garmin side sounds right too.
