Data Log - G-Meter
rfazio1951
Do the data logs record the g-meter readings? I can't seem to find it. I was looking at the logs to see how I was doing while performing a loop. Airspeed in my RV-6 ranged from 135 knots at the start to down as low as 54 at the top of the loop. I was curious as to the G readings, just to see where it was at different parts of the loop. I would think the logs should have the G readings?
tobb
I can't find "Vertical acceleration" on the parameters list within savvyAnalysis. Does the g-meter only record data when it's not hidden? cause I have set my g-meter to popup after a certain amount of gees, and i rarely exceed that limit.
I have attached a data log.
  • 2014-01-02-SEMFS-7_1_0_1999-BLACK_BOX_LOG_DATA.csv
Vertical acceleration is always recorded if you have an AHRS. However, SavvyAnalysis doesn't show you all parameters that are in the file, since they are a service that focuses on engine monitoring, not other flight analysis. So I don't think they have a way to show you Gs. There's actually 76 parameters in our log file!
