Datcon Oil Pressure Senders
Bonnell65
Tampa, FL
Seems Rotax (Lockwood) is moving towards Datcon pressure senders. Is there any current sensor pin that corresponds to the Datcon electrical match (resistance), common ground sender? I have a 0-80 psi 240-33.5 Ohm, 0-5 bar sender.
The other question I have is wiring. There is a single 10-32 pole on this sender. Do I wire pin6 or pin15 for this pressure sender?
Or...do I have to generate and map a custom sender definition for this?
Thanks,
Corey
It's possible, but I couldn't guarantee, that these are the same as our part number 100411-001. That would mean you'd just hook it up per the manual for that type, and select that sensor. Else, you're into custom sensor territory. What engine is this going on? We'd generically recommend using the sensors that we sell and know work well with our systems.
