There are no fuses or anything like that to check. The first thing to do is to pull ALL power from it, and this means the internal battery as well, if you have one. Just pull the rear door and then unplug the connector that is right there. You also need to pull keep-alive if you have it, but that happened when you pulled the D25 connector.
Once you have removed all power, if adding power back doesn't turn it on and you are sure that it has power at the connector, then we'll need to look at it here.
