Not quite. The encoder colors don't match the DB37 harness colors, to answer your first question. Don't ever assume that same colored wires on different harnesses match up. They're often designed years apart, before other harnesses were even a twinkle in our eye, and there are only so many wire colors in the world. So, if you're using Serial 1, you'd want the brown/orange stripe to go to the green wire on the encoder converter, and then the ground wire on the encoder converter goes to any ground, either one of the SkyView grounds, or some other ground. Ground is ground is ground. If you don't have it already, grab the latest version of the installation guide from the documentation section of our site.
