Display quiting?
8181C
Quick Question.. As we know here in Wa it seems to always be damp and wet.  Last Saturday was no different.  I had the aircraft outside all morning getting wet and cold soaked at an airshow.  When I jumped in to perform during the show, I turned on the skyview and it was washed out to the point where you could barely see the display with vertical lines going through the picture.  This is the first time I have ever seen this, but than again flew for the past 8 years in the phoenix valley and not Wa.  Is this a sign of bad things to come? or is this a known issue?  :-[ Needed to add one thing... I cycled power and display returned to normal again. :eek:
You definitely shouldn't be seeing that. Give our support team a call at 425-402-0433 or an email at support at dynonavionics.com. Has it happened more than once? If it happens again, a picture would help immensely.
vasper
Mine has been doing that as well. If I tap on the display (not a touchscreen!), it returns to normal for awhile but it's pretty annoying. I live in Mississippi where it's very humid so moisture might be involved.
vasper
Here  is a photo of my 7" display taken this morning.  I'll send some of these to support as well.
Yeah, that's definitely a hardware issue. We'll need to see the display to determine whether there's moisture contamination or anything that might be the underlying cause, but ultimately we'll want to have you send that in.
