Does your oil temp sensor leak?
Ratman
I recently installed the Dynon supplied 5/8-18 UNF (Dynon P/N 100409-001) as described in the manual. This sensor has straight threads (like a bolt) and my accessory case, like most Lycoming cases has pipe thread so there was little doubt that it would leak. The manual calls for a crush washer but even with the proper crush washer, you still have the wrong threads to deal with.
If the sensor backs out in flight at the very least you will have a very nasty oil leak to clean up. What's worse is the very real possibility of serious engine damage and a forced landing.
If you installed this sensor in your engine and it didn't quite fit please take a close look at how it fits and does it leak. If you have this sensor in an airplane that you bought you should be concerned as well. I've done a lot of searching on several different forums and found comments like "it leaks a bit" or "I couldn't ever get it to stop leaking".
I called Dynon about this as well and was told by the person I spoke with that he hadn't heard of a problem although he admitted he hadn't actually ever seen an accessory case on a Lycoming engine, searching this forum found the same thing, they hadn't heard of a problem.
The fix is relatively easy. Call Dynon and order the smaller 1/8-27 NPT (Dynon P/N 100409-000), it's a $20.00 part. This sensor HAS pipe thread but may be too small for the accessory case. If it is simply get a brass bushing (reducer), a $3.00 part. Mine required a 3/8 to 1/8 bushing and does not leak.
Not trying to wave a red flag here although, I do think Dynon needs to take a serious look at their instructions as well as the suitability of the sensors offered. If it's not the proper thread, it's not the proper part. Just don't settle for close enough or even a small oil leak, it could bite you later.
PhantomPholly
Good post Ratman.
Please post this in the appropriate section of the Wiki, and hopefully Dynon will incorporate all the lessons learned from the Wiki into their next version of the Manual.
s24789
Hobe Sound, Florida
I had the same luck with mine. What is the Dynon recommended repair and if there is one why is this not with the instructions ?
bbtapb
The oil temp port for Lycoming is not a pipe thread. It is as Dynon describes. There's a VERY important note in the installation manual to add the copper crush washer. Frankly, it should be included with the sender.
Bob
ahouse
Mesa, AZ USA
My O360 is definitely pipe threads, I am using the one that came out for now, but it reads appx 25 degrees low at ambient. Is there a replacement yet, or should I use the continental npt part no. (100409-000) and bush it?
ahouse,
Is your sensor type set up correctly? If you continue to have problems with it reading the wrong temperature, please contact our tech support.
-Dynon Support
