don't connect wires
mataylor
Colusa, CA
What are people doing with the wires labled "do not Connect" on there D-180. Just bundling the wires and securing them behind the panel? What are they for, future use? I also have a yelow/green wire coming out of the 25 pin connector I can not figure out. Without opening up the connector does anybody know which pin this is from.
If you're talking about pins 1 and 3 on the 37 pin connector, they'll never be used on that product. They're the main power and ground lines when that same harness is used on an EMS-D10 or EMS-D120.
The yellow/green goes to the serial input wire (usefull for connecting or an GPS/SL30).
mataylor
Colusa, CA
Actaually I was talking about red wire coming from DB37 harness pin 1, yellow from pin 2, and the blue green wires from pins 34, 35, 36, and 37. Thanks
