Door warning message / audio alerts
easyhouse
Merritt Island, Fl
I have a canard type plane where the door locking is very critical. I have micro switches to indicate that the doors are locked, but is there a function in Skyview that I can get a warning message and/or audio alert if the doors are not locked and the airspeed or GPS speed is greater then 25 or so knots?
You can hook up switches to the doors and have them tied to alert conditions via a "contact" input on the EMS module, but SkyView doesn't have a way to tie in other conditions like speeds.
MCRider
Germany
If you are are ready for some DIY engineering:
You can use a simple single-board computer that receives the serial data stream from SkyView (which includes the airspeed and should also include the status of contact input) and drives a warning light, generates a beep or maybe even voice output.
I have built a module using an Arduino Pro Mini board that prevents flap deployment above Vfe. It works fine.
MCRider
ggerhardt
I've been thinking of doing something similar. I'm new to arduino, tho - would you mind posting your code? I'd like to see how you parsed the Dynon data stream.
Thanks.
Geoff
MCRider
Germany
Geoff,
No Problem - here is the code. Please note that I am not a software engineer, although I have a professional background in hard- and software engineering. I tried to keep everything as simple as possible rather than creating a masterpiece of software design. A major part of the code is just for debug output.
Everything you might do with the code is at your own risk!
MCRider
// #define DebugOut
Flap overspeed detector for MCR01
The circuit:
  * Arduino Pro Mini 328
  * Status LED attached from pin 13 to ground
  * Serial out from Dynon SkyView connected to pin RXI, 9600 baud
  * Sparkfun MAX3232 Breakout to convert serial signal level
  * Relay output pin 11, relay normally closed, interrupts flap down control signal
Functions:
  * Reads airspeed from EFIS data stream (ADAHRS data)
  * If airspeed is valid and above limit relay is activated
  * LED: no valid airspeed data -> LED off, valid airspeed data -> LED on, airspeed to high -> LED flashes
Changes:
V1 (2013-12-17): Inital version
Test data lines:
  !1121144703-014+00003310811+01736+003-03+1013-033+110831245+01650023176C
  !1121144703-014+00003310711+01736+003-03+1013-033+110831245+01650023176B
  !1121144703-014+0000331XXXX+01736+003-03+1013-033+110831245+016500231702
// Constants
const int cPinLedOnBoard = 13;      // on-board status LED pin
const int cPinRelayOut = 11;        // Relay output pin
const long cBaudrate = 9600;
const int cMaxAirspeed = 760;       // Max airspeed to move flaps down in knots * 10
const int cRecBufferLen = 0x100;    // Length of receive buffer
const int cMaxBytesAtOnce = 16;     // No. of bytes read from EFIS in one Loop()-cycle
const char cReqLineType = '1';      // Line type of SkyView data
const char cReqDataVersion = '1';   // Version of SkyView data
const int cPosAirspeedData = 23;    // Position of airspeed data in line
const int cLenAirspeedData = 4;     // Length of airspeed data
const int cIntervalLEDFlash = 200;  // Length of cycle (msec) for flashing LED
const int cDelayRelay = 500;        // Minimum delay (msec) before relay state changes
const int cTimeoutAirspeed = 5000;  // Time (msec) without valid data from SkyView before last airspeed gets invalid
// Global variable
unsigned long TimestampAirspeed;    // System time of last successfully received airspeed data
int Airspeed = 0;                   // Current airspeed
bool ADAHRSDataValid = false;       // Valid data from ADAHRS available
int ReadCount;                      // Counter for reading data
bool Reading = false;               // Currently reading data?
char RecBuffer [cRecBufferLen+1];   // Receive buffer
bool LEDFlashOn = false;            // LED currently on? (for flashing LED)
unsigned long TimestampLEDFlash;    // System time of last LED status change (for flashing LED)
bool RelayOn = false;               // Relay currently active?
unsigned long TimestampRelay;       // System time of last relay status change
void setup()
    pinMode (cPinLedOnBoard, OUTPUT);
    digitalWrite (cPinLedOnBoard, LOW);
    pinMode (cPinRelayOut, OUTPUT);
    digitalWrite (cPinRelayOut, LOW);
    Serial.begin (cBaudrate);
    TimestampLEDFlash = millis ();
    TimestampRelay = TimestampLEDFlash;
    #ifdef DebugOut
      Serial.write ("Setup\n");
    #endif
long int TimeDiffMillis (unsigned long Then, unsigned long Now)
    if (Now >= Then)
      return Now - Then;
    else
        Then = 0xFFFFFFFF - Then;
        return Now + Then + 1;
void UpdateLED ()
    if (!ADAHRSDataValid)
    else
        if (Airspeed <= cMaxAirspeed)
          digitalWrite (cPinLedOnBoard, HIGH);
        else
            if (TimeDiffMillis (TimestampLEDFlash, millis ()) > cIntervalLEDFlash)
                LEDFlashOn = !LEDFlashOn;
                if (LEDFlashOn)
                else
void ReadEFIS ()
    int i = 0;
    char c;
    while (Serial.available () && (i++ < cMaxBytesAtOnce))
        c = Serial.read ();
        if (c == '!')  // Start of data detected
            Reading = true;
            ReadCount = 0;
            #ifdef DebugOut
              Serial.write ("! found\n");
            #endif
        if (!Reading || (ReadCount+1 >= cRecBufferLen))  // Not reading or buffer overflow?
          return;
        if (c == 0x0D)
            Reading = false;
            #ifdef DebugOut
              Serial.write ("End of line\n");
            #endif
            char TmpStr [cLenAirspeedData+1];
            byte Sum, CheckSum;
            char *Ptr;
            // End of data detected
            if (ReadCount < 5)
              break;  // Too short
            RecBuffer [ReadCount++] = 0x00;
            #ifdef DebugOut
              Serial.write ("Line: ");
              Serial.write (RecBuffer);
              Serial.write ("\n");
              Serial.write ("Data: ");
            #endif
            Sum = 0;
            for (int j=0; j < ReadCount-3; j++)
              Sum += RecBuffer [j];
            #ifdef DebugOut
              Serial.write ("Chksum calc: ");
              itoa (Sum, TmpStr, 16);
              Serial.write (TmpStr);
            #endif
            strncpy (TmpStr, &RecBuffer [ReadCount-3], 2);
            TmpStr [2] = 0x00;
            CheckSum = strtol (TmpStr, &Ptr, 16);
            #ifdef DebugOut
              Serial.write ("Chksum from data: ");
              itoa (CheckSum, TmpStr, 16);
            #endif
            if (Sum != CheckSum)
              break;  // Checksum not correct
            if ((RecBuffer [1] != cReqLineType) || ((RecBuffer [2] != cReqDataVersion)) || (ReadCount < cPosAirspeedData + cLenAirspeedData))
              break;  // Wrong line type, wrong data version or data too short
            ADAHRSDataValid = true;
            strncpy (TmpStr, &RecBuffer [cPosAirspeedData], cLenAirspeedData);
            TmpStr [cLenAirspeedData] = 0x0;
            #ifdef DebugOut
              Serial.write ("Airspeed: ");
            #endif
            Airspeed = strtol (TmpStr, &Ptr, 10);
            #ifdef DebugOut
              itoa (Airspeed, TmpStr, 10);
              Serial.write ("Airspeed read: ");
            #endif
            TimestampAirspeed = millis ();
        else
          RecBuffer [ReadCount++] = c;
void SetRelay ()
    if (TimeDiffMillis (TimestampRelay, millis ()) > cDelayRelay)
        bool NewRelayOn = ADAHRSDataValid && (Airspeed > cMaxAirspeed);
        if (NewRelayOn != RelayOn)
            RelayOn = NewRelayOn;
            if (RelayOn)
              digitalWrite (cPinRelayOut, HIGH);
            else
            TimestampRelay = millis ();
            #ifdef DebugOut
              if (RelayOn)
                Serial.write ("Relay on\n");
              else
                Serial.write ("Relay off\n");
            #endif
void loop()
    ReadEFIS ();
    if (ADAHRSDataValid && (TimeDiffMillis (TimestampAirspeed, millis ()) > cTimeoutAirspeed))  // last valid airspeed too old?
        #ifdef DebugOut
          Serial.write ("Timeout\n");
        #endif
    SetRelay ();
    UpdateLED ();
MCRider
Germany
Some more information:
MCRider
As an FYI, there is an undocumented feature in SkyView (used by an OEM) that allows a warning on a canopy being open, and above a certain RPM. The point is to warn you on the canopy being unlatched during your runup or as you taxi out, long before you have achieved a significant airspeed.
It can't say "door" or trigger on airspeed.
If you want to use this, you need to edit the config file yourself:
CANOPY_WARN_RPM=X
You then need a contact named CANOPY. If it is in the state named OPEN and the RPM exceeds X, you will get an audible "CHECK CANOPY" alert.
TRCsmith
Suisun City, CA
Or you can do what I do. If canopy comes down it gets locked. That's it! No taxi around holding it 2 inches open. It's either full open or full closed and locked! end of story. No warning system.. 11 years and a a 1000 hours of flight time in it.  :cool:
