DSAB connections
DBRV10
Brisbane, Qld. Australia
I have read the D100 and D180 manuals and I see that the pins 4&5 are for the DSAB on the 25 pin connector, and when you see the table showing pins 34,35,36 & 37 it says DO NOT CONNECT.
This I can see as OK as the D180 gets a DSAB connection on pins 4&5 and does not need the 34-37 like a D120 would.
Only thing that upsets all that is the D100 manual has a drawing showing connection to a D180 using pins 34-37.
So what is the deal here? I assume its a printing error in the drawing, but I want to be sure before I build the harness. Easier to fix in the drawings!!!
We will have D100 / D180 / HS34 / AP76 / Servo's.
Thanks in advance
David :)
David,
You are correct that there was a printing error. The D180 does not have active DSAB connections on pins 34-37. Sorry for the confusion.
