Dual SV-GPS-250 wiring?
RudiGreyling
South Africa
Skyviewers,
I am confused, how to wire Dual SV-GPS-250 to 2 Skyview Displays...
P8-3 "If there is more than one SV-GPS-250 in your system, use the same scheme in fig 47 but on different display serial ports fo the othe SV-GPS-250 modules, but connect power and ground 'together'
I also found this
Does this mean I need to connect the second standby GPS-250 to RX4/TX4 for instance in the place of the "portable GPS"
I dont want to "waste" another serial port for the standby GPS-250, ports 1-4 are all already used.
Maybe I should just give each skyview display its own GPS-250 and not link the two skyview RX5 and TX5 together.
Will that work or is there a better method without using another Serial Port?
Thanks in advance.
Rudi
It does, but you can alternatively connect each SV-GPS=250 to a single display. The tradeoff is that if a single SV-GPS-250 fails, the display it's connected to will lose GPS. It does save you a serial port for other devices, though, while still giving you redundant GPS (albeit not across the whole system, all the time). Hope that makes sense.
