Dual tank fuel flow
GHDZ
KSGJ/TJBQ
Can you connect two fuel flow transducers (different tanks) to the EMS? If so, can the SKYVIEW display remaining fuel per tank and the total remaining? :cool:
No, it can only tell you about the total fuel state based on all of the fuel that passes through the fuel flow sensor. However, resistivity/capacitive fuel tank sensors can be hooked up to give you completely independent per-tank quantity indications. Having both is a great way to cross-check.
