mwilli7119
- Joined
- Nov 2, 2006
- Messages
- 1
I am aware that this is a stupid question, but I have to ask it just to make sure...
The diagram that came from Microair for wiring the transponder to the Dynon encoder converter shows the black wire going to pin 15 but the diagram shows it turning at 90 degrees and terminating on a dot after it crosses the red wire. What does this indicate? simply that the black wire eventually goes to ground? a jumper between the red and black? somthing else?
you can see the diagram at: http://www.microair.com.au/admin/uploads/documents/T2000SFLwiringdiagramwithDynonencoders1.pdf
