Dynon D100 Efis and Ems D10 Upgrade Problem
Flie
Righto all you Jabiru 230 owners with an Efis, Ems and Avmap and SL30 linked.
I thought it was time to upgrade the Dynons with newer software
( 5.1.1 )which all went very well.
But on a flight to Hamilton yesterday on trying to split the screens the Efis wont pull over the Ems screen. It says No Ems connected and I am also unsure if the other instruments are synced or not.
Help please.
I thought no probs it is just a setting- but cannot find anything that helps on the instruments, dynon site or the manual.
Any Ideas ??
Terry
Australia
First, did you update both the EFIS and the EMS? They do need to be on the same version.
You likely need to re-do a DSAB config to make them talk.
Also, we released 5.2 in the middle of this week so you should consider going to that version.
Flie
Thanks for the prompt reply.
Yes I updated both to the same version. Not sure how to do a dsab config but will search the forums and get back if I am still having a problem.
Terry
Flie
Thanks Dynon support for your help.
Yep, I did a Dsab config and things are fine
Thanks again
Terry
