I have a D100 and a wiring harness I bought through aircraft spruce 3-4 years ago. I just bought an SL30 and was hooking it to my D100.
The wiring diagram says to connect the pin 22 from the D100 to the serial out pin on the SL30. The pin 22 on the D100 has a splice in it just after it leaves the DSUB connector. There is a solid yellow wire (that is bundled with the black and orange wire that leads to the 9 pin DSUB) and a yellow/green wire.
What does that yellow green wire connect?
I connected the Dynon pin 22 (solid yellow bundled wire) and the serial out wire on the SL30. I then connected the D100 pin 10 (orange bundled wire running to 9pin DSUB) to the serial in pin on the SL30.
I have the D100 set to SL30 and baud rate of 9600. I have indicator type on the SL30 set to none.
I went flying and the SL30 works as it should, but the Dynon HSI is blank....no information is getting to it.
There are hundreds of the D100/SL30 combinations flying without a hitch, so Im sure we can figure this out.
Any suggestions on what I have done wrong?
