Dynon GPS and Roll steering
rogersmart
Is there a setting or other method that causes the autopilot to anticipate a turn and "cut the corner" while using the Skyview GPS. (similar to a 430 GPS roll steering)
By default this is on, but can be turned off in a flight plan by "toggle overfly" on a waypoint.
So generically, you need to disable it, not enable it.
You can see the path it will follow right on the map. You do need to be in flight since it needs ground speed to calculate that. You also need firmware that isn't more than about 2 years old.
Is it not working for you?
rogersmart
Thanks for the quick answer.
My firmware was V14-something (one before the current one)
I noticed the other day on a trip when I flight-planned around Class B, it started the turn at the waypoint instead of before, however I did get a countdown to the turn.
It was a shallow turn so let me test it some with tighter turns and I will get back.
Thanks again.
