- Joined
- Mar 23, 2005
- Messages
- 13,226
Hi all,
We're for folks that have autopilots installed and flying, particularly D10/D100 series customers, who are running the latest firmware (5.3 currently), and have tried everything they can to dial in the autopilot - particularly in pitch - but aren't quite seeing the performance they would like. If this is you and:
-you're fairly technical - you understand how to use the Dynon Support Program to load firmware into your unit and you're comfortable with that process
-you're available to fly and iterate firmware and report back at least a few times over the coming weeks and months
-you're patient and fault-tolerant, and understand that testing "beta" firmware is an experimental thing
...then we want to hear from you. Please email betatest at dynonavionics dot com with the following information:
-airplane type
-dynon equipment, particularly, which servos you have
-roll axis setup:
servo type
short description of mounting method
all settings from the roll axis page in the ap setup menu
your performance notes/issues (in turbulence and smooth air if they're different)
what you've done so far (settings tweaked, results,etc) to try to dial it in
-pitch axis setup:
servo type
Thanks!
-airplane type
-roll axis setup:
servo type
-pitch axis setup:
servo type
Thanks!
