Dynon Skyview 3.2 Screen Problem
ge
Help - I think I have a faulty Display.
My system has 2 Skyview SV-D700 displays (left and right)
The left display works perfectly well in both positions (left and right). The right display appears as shown in the attachment in both positions (left and right).
During boot up of the right screen, the Dynon Logo appears "pixellated" and a fragmented screen appears  for a short time. After boot up the GPS has the red cross and there is flickering interference in the lower right corner of the screen.
Again, the left screen works perfectly well in both positions.
The right screen has been configured correctly and does show GPS RX activity in the counter depite the red cross.
Any help appreciated
Geoff Eather
So in addition to the RX counter, is the "good" sentences running up? If not, SkyView doesn't thing it's seeing a valid GPS signal. What is the GPS, incidentally? On this one, I'm suspecting a configuration thing.
The display thing probably isn't related, but from the picture does look like a hardware failure just the same that we'd need to see here to fix. Give tech support a call at 425-402-0433 or an email at support at dynonavionics dot com.
ge
You are right. There were good sentences but the configuration was incorrect (I had "none" instead of "Position 1" in the port setup menu). This is despite checking 52.3 times!!!
The interference on the screen however remains. I will contact you via Dynon Support with additional pictures
ge
