Hello,
I bought the Dynon AOA, Pitot, Static Plumbing Kit. In the directions it says the static port should be mounted proud of the aircraft skin. I'm not exactly sure what proud of means. I would think that means the entire static port should be mounted on the outside of the skin.
Then it goes on to say "Drill a 1[ch8260]2” diameter hole (12 mm) from which the port will protrude". A 1/2" hole would seam to indicate that it will be mounted on the inside of the skin with just the small 1/2" port protruding.
Maybe I can't see the forest for the trees here, but I'm looking for some confirmation on exactly how the static port is intended to be mounted.
In my case, it will be mounted to a fabric fuselage.
Thanks!
Thanks!
