B.Blenden
I have read the read the installation manual regarding the transponder hookup and note that the power is to be supplied by a dedicated circuit protected with a 3 or 5 amp breaker. Do I need to install a switch for power on/off to the transponder or is it controlled from the EFIS display. I will use a circuit on the Avionics Bus so the power lead will not be hot until the Av Master is switched on.
