I just bought an airplane and I am trying to fix this annoying issue. When I start the EFIS-D10A, it detects perfectly the EDC and the OAT for about 10 to 40 seconds then it displays Remote Compass not Detected and OAT not found. I turn the EFIS off and on, the same thing happens again. If I disconnect and reconnect the EDC's DB9, I get the same result. Just short connection time. Removing the OAT gave the same result.
This is the setup:
EFIS Firmware to V4.04 (I do not upgrade as I read I should have EDC communication first)
Harness is from Dynon.
All connections looks good and works for few seconds.
Has anyone have any insight? I suspect the EFIS or the EDC is damaged.
Thanks.
This is the setup:
Thanks.
