K
Keith Southard(Guest)
I just went through the process of shortening the OAT probe leads and some minor re-routing of the wiring harness to the EDC.
I also upgraded the software in my EFIS D10 to the latest version 1.12 from 1.5.
When I reconnected to the EDC and powered up the D10, the OAT info wasn't there. I checked using the support program and it says 'no edc detected'. I manually rotated the EDC an noted no change in the heading indicated by the EFIS.
Wiring and the connector has been double checked and verified as correct. I am using a harness from Stein Air. They do a nice job of labeling the pins and I have verified that they are in and connected properly. What is the next step?
