gbabcock
I have an EFIS-D10 and I'm trying to install the EDC-10 and OAT. I built the EDC cable and successfully tested the EDC (magnet near the EDC affects indicated heading). I wired in the OAT and got a reading on the EFIS, but it was not reading accurately. The calibration could not correct it, and the indicated DA was also wrong.
I read in this forum that this could be a problem with the firmware version of the EFIS being different than the EDC. I had previously upgraded the EFIS firmware to 1.12 without the EDC connected, so this was the case with my units. I downloaded the Support Program (v2.4.3) and ran it. It showed the firmware versions of both the EFIS and the EDC. I then backed up the old firmware and ran the upgrade to 1.13 with the EDC connected.
Once the upgrade was complete the EFIS came up, but the EDC did not. The Support Program says the EFIS is now 1.13, but the EDC is "not detected". I did a cold start of the system but no joy. I tried restoring the backed up firmware but this didn't restore the EDC either.
Can you help me?
Can you help me?
