WestCoastOz
My D100 was factory installed in my CTsw using the mounting bracket supplied by Dynon. I have had issues with the EFIS slip ball being 1/2 a ball out to the left while the airplane is on the ground on a level surface and find that my flight controls are slightly crossed in flight when the airplane is trimmed with the ball centred.
Today I removed the D100 from the bracket (it was secured only by one 7/64 screw as mentioned on page 19 of the installation manual) however I noticed that at the back, the aluminium bracket was somewhat distorted as though it was tightened excessively in order to keep the D100 firmly against the instrument panel. In the manual it says you can also use a #6-32 screw on the other side, from the back to the front and am wondering if anybody has done this and has it made a difference.
I am hoping that by adjusting the D100 into the level position so the ball is centred, it may overcome the trim problem I am having, however I need to be able to secure the unit firmly, hence my question.
Anybody?
Dave
Anybody?
Dave
