EFIS D100 when?
F
Frank(Guest)
HI,
Can you tell us when the large screen EFIS will start shipping?
Frank
We're hoping to begin shipping EFIS-D100s in the coming weeks.
F
frank(Guest)
Hi guys,
Can you give us an update on the D100 likely ship date?
Frank
ozzie
My new LSA plane is due for delivery late Nov 05. The panel includes a D10A though this has not yet been ordered. However, now that I have read the D100 web info, all is confusion. If I ordered NOW, would a D100 be available by early Nov to enable a factory fit to be accomplished, or will I be at the end of a very long queue?
Regards
Ozzie
Frank: EFIS-D100s have started to trickle out but we are not yet up to full production capacity. It is still hard to nail down lead times.
Ozzie: I assume you will be taking delivery of an S-LSA. In this case, our understanding is that the manufacturer has final authority on what options can and can not go on the plane. They essentially "certify" the configuration. Even after delivery, modifications need to be per the manufacturer's specifications, and so installing an EFIS-D100 bought after the fact may not be possible if the manufacturer does not approve it for installation in their aircraft. As for availability - if you were to order an EFIS-D100 directly from us it would be queued up like any other order. Your particular manufacturer may or may not be offering the EFIS-D100, though, and further may or may not already have some on order. You should check with them about their plans and availability.
F
frank Hinde(Guest)
But I'm #15 from the front of the list so presumably it won't be much of a trickle before you get to mine right?
Frank
