Hello all,
I received a pretty early D10A (S/N 3896) with it's magnetometer EDC-D10 which I provided to upgrade to the latest firmware as it apparently had a very old one (2.8.6). The upgrade process went smoothly and both the EFIS and EDC were upgraded to parallel versions without a glitch.
My question now is that apparently there is a problem with a barometric sensor as the displayed altitude is always -1200ft and doesn't budge. The anemometer only moves when some slight depression is sensed on the static tube - but nothing happens when gently blowing on the dynamic/pitot port. A slight breeze from a ventilator is enough to budge any instrument but this one doesn't move on this port. Now apparently the instrument was discarded some years ago probably for this reason at this point (I have no clue of it's history) so I was just curious to know if there was some debug or self test mode I could enter to check the capsules' operation and their relevant MCUs. No errors are reported at power-on or during testing. All accelerometers appear fine.
I suspect a faulty component at this point but before abandoning hope any suggestions are welcome!
